Dekalb P25 TRS need help
stonek554
GA
Does anyone have a current scan of Dekalb's P25 system? I am trying to id the control channels, System id, WACN, RFSS, and site. I know these are already posted in the database, but something appears to have recently changed as my radio will not pick up the system anymore.
Metrofire31
Auburn-Opelika, AL
Stonek554 - I work in DeKalb and monitor them constantly and the data here on RR for them is current and correct. What more can I tell you?
Metrofire31
N8IAA
Fortunately, GA
What radio?
Larry
stonek554
GA
I am using a Harris XG-100. For some reason I am not picking up the Dekalb control channel anymore.
N8IAA
Fortunately, GA
Unless you are authorized on their system, they can shut your radio down.This is why most use a scanner capable of receiving P-25 signals.
Larry
stonek554
GA
The radio is set to not affiliate and has transmit capabilities disabled. With no system key, no affiliation, and not transmit enabled it is basically an expensive scanner. For systems I am authorized on I have full capabilities. Just prefer to use one radio.
