Delaware County Fire Tone Out-Station 20 requested
Mattsenft
Harrisburg, PA
My fault for not reading carefully. I have no idea what the tones are, but I can help you troubleshoot programming. Make sure the signaling system you set up for QC II is enabled for the channel. If I recall correctly I believe that several RSS programmed radios would only let you program 1 signalling system per channel. If you have a PL or DPL signalling system set up for the channel you may need to change it.
