Delaware county SO
KOK5CY
Claremore,Ok
Im a little confused about this and hopefully someone can explain . I'm using the tram 1091 on a mag mount on the cab of my truck and I'm receiving the sheriff's dept and there deputies from the Claremore toll gate area . Is there tower on a hill or are they pushing power being on vhf high ?
HogDriver
Oklahoma City, Ok.
I’m a little confused! Are YOU at the Claremore gate or the sheriff at the Claremore gate??? Where are you??? What Sheriff???
KOK5CY
Claremore,Ok
I live near the Claremore , Ok Toll Gate .
I'm asking why am I receiving the Delaware County SO and deputies all the way over in Rogers County and I'm using the tram 1091 .
HogDriver
Oklahoma City, Ok.
May be skip. There’s been some solar activity the last few weeks and I occasionally pick up stuff from 75 miles away.
WG5Z
Inola OK
Yes sporadic E skip can happen and allow very long distance reception. I once talked to a guy in Havana on 2m ham with only 100 watts. You could be experiencing a thermal inversion layer. This can cause a tunneling effect allowing vhf to travel maybe 100 miles. I occasionally hear McAllester SO vhf which is about 75 miles away. Inversions happen usually in the morning when the sun first starts to heat the atmosphere. There are other factors that influence reception. I monitor the Marine Band. I will hear the CG info broadcasts for the KM nav. waterway. I am kind of at the edge of their ground wave propagation and it will be from crystal clear to just barely above the noise. You may be right at the edge of their radiation pattern so depending on conditions you may or may not pick them up.
