Delete a favorite from profile
omlbed
Yes. From marksscanners.com:
Delete Favorites List Click to select the Favorites then Delete
Or, right-click any list and select Remove from Favorites List.
omlbed
Additionally, to have that favorite list removed from your scanner you will need to do the Write to Scanner function with the Erase Favorite Lists on Scanner option checked.
tvengr
Well Known Member
Baltimore County, MD
Be aware that if you delete a favorites list, it deletes the favorites list from every profile. The favorites list is gone forever. If you want to remove the favorites list from a single profile, go to the Profile Editor and set Download and Monitor to Off for that favorites list.
fxdscon
¯\_(ツ)_/¯
If I have 4 favorites but want to delete # 2 will this delete #3 and #4?
No, if you delete only favorites list #2 in Sentinel, that is the only favorites list that will be deleted... but as mentioned, favorites list #2 will be deleted in all profiles, if you are working with more that one profile. Also as mentioned, to be sure that favorites list #2 gets deleted in the scanner, when you write to the scanner from Sentinel, check the "erase favorites lists on scanner" box.
That will erase all favorites on the scanner, and then immediately write your new setup for favorites from Sentinel to the scanner (everything that was on the scanner minus favorites list #2).
tvengr
Well Known Member
The favorites lists are shared by every profile. You can delete favorites list 2, and that will not affect favorites lists 3 and 4. Delete a favorites list only if you never want to use it again. You can set whether you want to use it or not in each profile.
ofd8001
Louisville, KY
Unless you are absolutely, positively certain that you don't want the given Favorites List to ever be used again, it is advisable to export the Favorites List to an HPE file before deleting it. That way if you want to recover it, you can import it back.
