rnwjr said:
How do you backup the VFolders using the usb cable and WIN96... There appears to be no easy way to do that..
Not hard to do...Plug in and select Virtual Scanner under Scanner Menu
Click as follows:
1. Refresh (all V-folders (0-10) should load into dialog)
2. Read box on desired folders to save (you may check all boxes if needed)
3. Commit this will receive each folder checked in
2. Read (this will take time if all are checked)
4. Done click yes on dialog and all selected will line up on top of Win96
5. <VS folder 1> Select Settings/Weather Tab, highlight and copy line 4 of the Welcome Display
6. File Select Save and right click in the File Name dialog and select past
7. Save
Repeat 5-7 for each folder read.
