Deleting more then 1 freq.
upsmannj
Nutley, NJ
Just got my new TRX-1 can someone tell me how to delete more then one freq. at a time. I want to start over with other freqs, and don't want what I downloaded in it. thanks
Johnnydollar2
IL
Delete more than 1
I don't have a TRX-1/2 I have the WS1080. So unless there's some NEW stuff added to those over my version ... you do it in the EZScan software in the CONVENTIONAL or TRUNKED tabs. Score the first line with your cursor/mouse, press, hold down the shift key on the keyboard ..... then score/click the last line you want to delete. It should have selected ALL objects in-between bottom and top, then press the delete button on the side. And when you upload your new form to the scanner all things will be changed.
upsmannj
Nutley, NJ
did not work.
Well that did'nt work I had to click on each freq. one at a time holding down the ctrl tab.
Johnnydollar2
IL
More than 1 freq
That's odd. You click on the first line, hold the shift button down while that line's still scored blue or whatever color and making sure not to click anything else on the page... click the last line. All the lines should be scored in-between and be ready for batch editing. If you touch anything inside the page it won't work and you have to start again.
W6TUX
OBTW, upsmanj - I finally responded to your private message. Sorry for the delay, also sent an explanation.
Warm regards,
dave - W6TUX
Melv7956
Click first field Ctrl-A to select all is best I can offer and yes it works.
