Delta Airlines Flight 4230 Makes EMERGENCY LANDING!
btritch
Paragould/Greene County AR
Thursday 7:30 PM CDT Delta Airlines Flight 4230 Bound From Memphis International To Atlanta Georgia Has Turned Around and Made an apparent EMERGENCY LANDING shortly after take off due to Engine Problems...Several Reported Hearing Sonic Booms or Explosions and saw flames and Fire Shooting From the Left engine/wing area...The Plane Bound From MEM to ATL was carrying 75 People..No Injuries were Reported..Although The Memphis Fire Department Responded No Fire Was Extinguished Or Found On Board...Stay with the AP or Mempis TV Stations For More Information..
Airdorn
Cordova, TN
Just for an update.. I heard it just now on the scanner.
The same aircraft tried an engine run-up about 15 mins ago and it 'backfired', causing a fire on the runway.
Numerous fire depts. responded but it turned-out to be pretty minor. I've never heard so much activity on the fire channels. ;)
MattSR
Sydney, Australia
"Fire, explosions" - Yawn.. gimme a break...
Its called compressor surge - makes a bit of noise and some flames shoot out the back - Its analogous to a car backfiring... There is no real danger to anyone as long as the engine gets a precautionary checkup.
Cheers,
Matt
Airdorn
Cordova, TN
Cheers,
Matt
Wow, they could have saved a bunch of trouble and just called you, the expert........
SCANdal
Silent Key
Hudson Valley, NY
Just like the New Jersey Forum?
Wow; who knew we needed an "Incidents and Breaking News" sub-forum for the Aircraft Monitoring Forum?
immelmen
well, he is right....it was a compressor stall followed by a surge....pressures build in the late stages of the compressor due to aerodynamic stalling of the blades(Compressor stall) the thrust simply goes back out the front of the engine and ignition is lost(Surge)....aren't you so glad you didnt ask
Nothing is damaged, there is no fire(actually the opposite, the "fire in the engine" is blown out) and its not a big deal....I have had this happen on an aircraft I was flying twice....in the SAME flight. simply drop to FL250 and do an air start....its the regs that require you to declare....this must have been a slow news day.
also, based on the flight number this was not a delta flight...but a delta connection carrier, probably ASA or ****ty Kitty.
