Hello,
Recently I found out that AMTS systems use Passport LTR and I need some closer sources of Passport LTR for testing of LTRTrunk. I found a local system licensed to Paging Systems, Inc but it is idle most of the time.
Well a few days ago I was searching around and found additional Passport bursts in the block licensed to Paging Systems, Inc. It has been mostly idle but became active over the weekend. As I listened I realized this is a low power Passport LTR system at the Fleet Center for the DNC. Various talkgroups are homed to all eight channels and it is busy. Some people are complaining about the lousy radios. About 30+ talkgroups in the 100-500xx range.
Site 100 No neighbors
217.1375
217.1875
217.2375
217.2875
217.3375
217.3875
217.4375
217.4875
I got a chuckle when I copied the callsign, PASSPORT.
If you can hear voice traffic or a burst every two seconds then you found the system. The system cannot be trunk tracked with a scanner. A computer program like LTRTrunk is needed.
Likely it will be gone by next week.
73 Eric
217.1375
217.1875
217.2375
217.2875
217.3375
217.3875
217.4375
217.4875
73 Eric
