Denver Area NXDN
WX4JCW
Stow, Ohio
Greetings,
I haven't seen any listings for much NXDN in the Denver area
a cursory search reveals one big player with several sites,
ill submit the info once i can confirm it, sitting in Aurora till saturday
WX4JCW
Stow, Ohio
First Ste is System 392 Site 2 RAN 2 Looks to be Grazi Communications
CH 182 = 452.262 the control channel
WX4JCW
Stow, Ohio
ill keep an ear out, have seen one IDAS show up
ScannerSK
Weld County, Colorado
It appears you are referring to the following system:
However, I just realized the Grazi Communications system (on 452.262 MHz) is showing as an LTR type system in RadioReference and not as a NXDN type system.
Shawn
WX4JCW
Stow, Ohio
yep they switched over, alot of SMR's are doing that
WX4JCW
Stow, Ohio
For Grazi there are 2 sites i can hear
452.2625 Site2 CC
and
464.7125 Site 1 CC
abqscan
DataBase Administrator
Moderator
AOA
I havn't heard anything on the UHF Grazi NXDN systems, only the VHF sites.
WX4JCW
Stow, Ohio
Im figuring out the Channel Assignments now, the problem is that I can hear both sites 1 and 2 and they use the same talkgroups, plus they arent busy but there is an ambulance company using them
abqscan
Moderator
AOA
Now that I said that haven't seen any action... on 464.7125CC, I'm seeing action. TG 43 is active on CHs 266,515,528. NXDN takes the fun out of the hunt since it gives you the system channel numbers.
Site 392-1
266 = 453.3125
515 = 461.4250
528 = 461.5875
778 = 464.7125 (Control Channel)
Site 392-2
182 = 452.2625 (Control Channel)
509 = 461.3500
548 = 461.8375
601 = 462.5000
TG 43 is an ambulance company.
tyytor
Wyoming
i am also trying to monitor the Telstar Communications from the Simpson Mesa site running DSD+ very quiet had one hit all week, how do you find the channel numbers?? got bcd426hp with nxdn upgrade
abqscan
Moderator
AOA
I haven't seen any action on the Telstar system.
WX4JCW
Stow, Ohio
Site 392-1
266 = 453.3125
515 = 461.4250
528 = 461.5875
Site 392-2
509 = 461.3500
548 = 461.8375
601 = 462.5000
You Rock, btw what was the math equation on this system
WX4JCW
Stow, Ohio
i figured out the math using Eric Cottrell's formula but the channels above 401 use 455 in the equation instead of 460 nice
abqscan
Moderator
AOA
Is anyone else getting CH 266 on site 1. I started listening to the system again on a different computer and I'm not seeing 266 come up. I'm wondering if it was a bad decode error from DSD???
abqscan
Moderator
AOA
I don't follow the 401 part. Here is the Algebra I used from Eric's post.
For Channels 1 to 400:
Freq = 450 + (( Ch - 1 ) * 0.0125
For Channels 401 to 800:
Freq = 460 + (( Ch - 401 ) * 0.0125
