Desk Mic RMN 5083A SETTINGS
P25Radio
Oceanside Ca.
I have the above mic listed . I can not get it to work with an Astro Spectra radio or consolette., The mic has dip switches under the cover. Does anyone know of the proper switch settings to get it to work on either radio. it has the standard Spectra mic plug.
RBMTS
internal Switch S-5
S5-1 Off Microphone hot all the time
On Microphone switched w/ PTT
S5-2 Off PTT doesn't change state of Monitor
On PTT changes state of Monitor
S5-3 Off PTT and Monitor Buttons Function
Separately
On PTT and Monitor Buttons both act as PTT
S5-4 Off Must Monitor before PTT
On Monitor has no effect on PTT
S5-5 Off PTT Ground and Audio Ground are separate
On PTT Ground and Audio Ground are common
S5-6 and S5-7 work in conjunction For Monitor Polarity
S5-6 Off On
Monitor Low Monitor
High
S5-7 On Off
S5-8 On Microphone AGC on
Off Microphone Level adjusted by pot
accessed
Through hole in rear of
microphone only
P25Radio
Oceanside Ca.
Thank you very much! Will try that tonight. Funny your avatar picture looks exactly what my old pick up truck did inside. Taking a SWAG a Mocom 70 cool old control head and the exact siren unit which worked very well!
