Can someone post the 10-Codes used by Desoto County? I assume they use the MHP codes but they use others that aren't on the MHP list. Thanks a lot.
Ron-Memphis
Thanks Matthew! I enjoy listening to Desoto County Sheriff, especially since a lot of Memphis has moved there. Like I said, I have the MHP codes, but Desoto uses some that aren't on the MHP. Thanks again if you can help.
Ron
While yer at it......how about sending the High Tech Redneck a copy of those codes as well......I listen to them when I can or if something is goin on around here in Nesbit.......I would like a copy of them as well......lemme know when you get them and I will be checking back here
THanks Matt for the 10 Codes maybe now I am follow the action a little bit better than I used to.....will definitely help knowing what our tax dollars are paying for these days.......thanks again
Joebaby
High Tech Redneck
Rednecks, Inc. of Northwest Mississippi
