DeSoto Parish DMR
Tim-B
Down South
I noticed that someone submitted updated info for the DeSoto Parish DMR used by the SO and Mansfield PD. I was up there a few weeks ago and I had those frequencies programmed into a BCD436HP in conventional mode with the audio type set to all. It only decoded about one-fourth of the transmissons. On the other three fourths all I heard was the rapid fire machine gun digital noise. Is there a specific way that I need to program those frequencies so the 436 will properly decode all the transmissions? I was just passing through the area so I didn't have time to stop and experiment.
AC0RV
Park Hills, MO
With the x36HPs you need to program each DMR single frequency as seperate system. What type of system (Cap +,etc).
One of the DMR systems that I have program is a single frequency system. When someone transmits. It shows the CC,Slot, TGID and the UID for each user.
I presume you knew that.
lamopac
Pollock, La.
I have Desoto SO and Desoto EMS programmed as DMR One Frequency Systems on my 436 and they work fine. I had Mansfield PD and Mansfield FD programmed as conventional channels and I got radio traffic on them as well as the color codes. You might try setting your conventional channel modulation to FM and set the audio type to digital and use the NAC/Color Code Search.
Tim-B
Down South
So tell me if this is right -
You have the SO frequency of 154.1 as a single frequency DMR system
The PD frequency 155.5275 and the FD frequency of 155.94 as conventional with modulation NFM, audio type as digital only and NAC/color code set to search.
What about these frequencies:
155.1075
155.115
154.7325
158.7675
155.6625
155.1975
What do I do with them? Just put them in as conventional with NFM, Digtial only, and Search?
lamopac
Pollock, La.
155.1075
155.115
154.7325
158.7675
155.6625
155.1975
That's right, the other frequencies would be programmed the same way as well.
