Determining Band Split on VX-5500L
eportel6607
South County, Rhode Island
Hi guys was hoping that somebody knows enough about Vertex to tell me how to determine the band split of a low band radio that I have. According to the Vertex specs they made a 29.7-37Mhz and a 37-50Mhz. I can't seem to find any label on this radio that indicates which one I have.
Anybody know?
C
kayn1n32008
ØÆSØ Say it, say 'ENCRYPTION'
Sector 001
Read the radio. The software will tell you which split you have. Another option is to connect to a dummy load and TX. Use a frequency counter to determine what frequency you are transmitting on, and see which split it falls into.
Sent from my iPad using Tapatalk
eportel6607
Thanks very much,
I don't have any way at this point to read the radio as I don't have any software..yet.
However I was told from the agency that donated these radios that were on 37.900Mhz. So I assume this means that the radios are in the higher 37-50Mhz range since it's over 37Mhz. Is this correct you think?
C
kayn1n32008
Sector 001
Thanks very much,
C
I can not answer, BUT if the agency was on that frequency, then yes I would say that would be a safe bet.
Best way is to read the radio though.
kayn1n32008
Sector 001
Ok thanks. Well I guess it's time to aquire the software and programming cable.
Thanks again,
Chris
Vertex a software is available at no cost once you create a user name on the vertex website. I do not have a link handy but poke around the website. Programming cables can be found on fleabay
