- Joined
- Dec 19, 2002
- Messages
- 785
- Reaction score
- 5
I'm a total novice at LTR decoding, but have decided to give it a try. I read that if you program the same frequency into each of the LCN positions (1-20) and then go into ID search mode, the # it stops on will be the LCN position for that frequency.
I've looked at the FCC data for a particular name, and I'm showing about a half dozen LTR freqs for the same site. I put one frequency into 20 systems in each of the 1-20 LCN positions, and start scanning. I find traffic on 464.275 on group LTR Test 5. I listen a while, and log only hits on the system with the frequency in position 5.
So I go to the next one. This one shows hits on LTR Test 3, 11, 15 and 7. Uh... Most of them were on 3, so maybe some anomaly?
The next frequency shows even more puzzling results. The frequency log on BCT396T Advanced Scanner Control shows a DIFFERENT frequency than is actually in the radio.
Does this make sense? Do I need to forget it, do a discriminator tap, get a DOS box, software, slicer and go that route, or am I on to something?
