Thanks again for all of the insights, recommendations, and education. It seems the Mills Communications NXDN network is comprised of two separate licenses, the already documented in RR DB WQMI535 and also KBK826. When combining these two site transmitter frequencies into one system, the CC associated with WQMI535 (452.6125) is found and LCN search begins working. I now have four of the six 100+ watt site transmit frequencies associated with LCNs and the programming is now tracking the system. I will continue monitoring and documenting and wanted to give a shout out to you all who helped.
Sweet!
If you don't mind (when your sure of the results), post them up here.. I have the system in my programing, but it is clearly incomplete
, although I'm rarely out that way; I wouldn't mind knowing how to set it up correctly. Not to mention you could submit the info.
Plus we've learned there's more to be found..
WQMI535 Hanover PA
Site 117-1 (RAN 1) Hanover
452.6125 CC CH# 210
453.01875 CH# ?
KBK826 Hanover/Menallen Twp PA
461.1000 CH# ?
461.2250 CH# ?
461.5750 CH# ?
463.8250 CH# ?
Site 117-? (RAN ?) Menallen Twp
461.3000 CH# ?
464.0750 CH# ?
WSO555 Aberdeen/Westminster MD
Site 117-? (RAN ?) Aberdeen
461.6000 CH# ?
463.6750 CH# ?
Site 117-? (RAN ?) Westminster
462.0000 CH# ?
463.2250 CH# ?
464.3500 CH# ?
464.9500 CH# ?
KBK827 Baltimore/Jonestown/Mt Airy MD
Site 117-? (RAN ?) Baltimore
451.2750 CH# ?
451.7500 CH# ?
461.1000 CH# ?
463.7500 CH# ?
464.8000 CH# ?
Site 117-? (RAN ?) Jonestown
451.6750 CH# ?
452.8500 CH# ?
461.3000 CH# ?
462.2750 CH# ?
Site 117-? (RAN ?) Mt Airy
451.5000 CH# ?
452.4750 CH# ?
461.7000 CH# ?
464.0000 CH# ?
And there may be more...
And not to derail the thread.
But, If you don't mind trying, You should be within range of the PAStarNet P25 site in Hanover.
It's not been confirmed that it's online, but would be on 859.6875 (if it is). Site 55
WRAJ230
And if you do happen to pick something up.. You could post it in this forum..
https://forums.radioreference.com/threads/pa-statewide-p25-phase-2-system.349313/
Thanks! Happy Sleuthing!
