Detroit Fire Programming for BC785D
JuggaloGold
If this is the wrong area to post this I apologize;
I have a Uniden BC785D scanner with APCO25 card that I need to have programmed for Detroit MI Fire Department. If anyone in the Detroit area can properly program the scanner or know where in the Detroit Area I can get it programmed please let me know.
Thank you
WayneH
Forums Veteran
Super Moderator
Sitting in an airport somewhere
Moved to the Michigan forum.
We consider posting the same topic multiple times as "cross-posting", which is against the rules. Please review the threads in the forum I link to in my signature. Failure to post in the correct forum could get you no help.
rdale
Lansing, MI
The 785D is not compatible with MPSCS, so you can't use it for Detroit Fire.
bsrepellant
Just to be more informative... The digital add-on card can only decode buad rates up to 4800 (I believe) the MPSCS is 9600.
rdale
Lansing, MI
Actually that's less informative ;) To clarify - the digital add-on card can decode the audio. So you can scan in conventional mode, but in Detroit that would be useless. That scanner cannot handle the 9600 baud control channel, so it cannot trunktrack.
