What deviation is used on the 220 MHz and 70 Cm bands? Thanks!
T tvengr Well Known Member Joined Feb 10, 2019 Messages 10,701 Location Baltimore County, MD Jan 3, 2025 #1 What deviation is used on the 220 MHz and 70 Cm bands? Thanks!
K kf8yk Member Joined May 3, 2003 Messages 788 Jan 3, 2025 #2 For analog FM 5 kHz deviation is the most common with a few users using narrowband at 2.5 kHz deviation.
T tvengr Well Known Member Joined Feb 10, 2019 Messages 10,701 Location Baltimore County, MD Jan 3, 2025 #3 Thank you very much!
E Echo4Thirty Active Member Premium Subscriber Joined Oct 6, 2021 Messages 936 Location Spring,TX Jan 3, 2025 #4 220 Amateur is typically 5kHz, 230 commerical is 2.5 kHz. That said, a lot of users are using commercial radios and may be limited to 2.5 kHz in the amateur band as well.
T tvengr Well Known Member Joined Feb 10, 2019 Messages 10,701 Location Baltimore County, MD Jan 3, 2025 #5 Thank you! It is probably better set a scanner to FM (5KHz) to avoid distortion for the wide band transmissions.
