I currently have both an SDS100 and SDS200, which work great for trunked systems. I'm currently trying to sort out a "system" of DMR frequencies, but from what I can make out they're using the frequencies conventionally, not as an actual system. One of the sites I've identified so far seems to be using a repeater, with a 5mHz step, but I have a pile of other frequencies they're also assigned that I'd like to scan through. The SDS100 will do this, but not super quickly, making the identification process trickier. (Obviously this wouldn't be its only use, but it is what I'm at least seeking initially)
I know that it has been mentioned that other, older models scan conventionally quicker, but I'm curious about thoughts anyone has on BCD325P2 vs BCD436HP. The 436 obviously has an advantage of being able to load from Sentinel what I've already built for the SDS100, but how does it perform scanning speed wise? Any pros or cons of one over the other?
Thanks for advice!!
Thanks for advice!!
