Hi all,
Electrically a discone is a discone, only those made for scanners have that loaded whip and extended "radials" making a groundplane for VHF Lo Band. Actually it's a modified discone, a cross between the two. The brand name doesn't matter, rugged mechanical construction does when it comes to long term reliability.
Right, the N connector being a low loss constant impedance device is MUCH better on those high frequencies but if you use ordinary RG-8U coax you lose the advantage and then some. You need Belden 9913 (only Belden makes it, accept no "type" substitutions) or that "gold plated" stuff if your wallet can stand the expense.
BTW, those who use RG-58U and complain the antenna doesn't work don't understand that type of coax is good for HF work only, loss on VHF is horrible and gets MUCH worse as the frequency goes up.
