Has anyone tried to use a Diamond SRH77CA with a the Uniden SDS100 Handheld scanner.
The SMA version does not connect to the center pin. It will not work.
This is great. Thank you!You can easily make it work.
I just Dremelled a shoulder on mine and it works great.
(I used Alumablack and a bit of shrink tubing for cosmetics)
Take your time. Take a bit off, check it and keep taking a bit off until it fits.
I’ve purchased just about every aftermarket antenna for my portable scanners. The claims about gain are subjective as gain can be measured in a couple of ways but I use the claims to compare anyway. My results are the Diamond and the other longer range gain promising antennas play about the same. The Diamond SMA won’t fit the SDS100 without modification but I didn’t bother modifying the antenna. Take that Dremel tool to the offending ridge on the radio’s case. I’ve collected both scanner antennas and ham radio antennas over the years and I can fit any one of them with the right adapter if needed without that damn ridge blocking me. Any advantage that ridge provides is highly outweighed by my want to change at will, my antennas, to the scanner.
If you do decide to remove the ridge using a Dremel tool, take care to make your cuts very short (length of time) to prevent heat from building up and melting the plastic. Make many short cool cuts. The results can be dressed up with a rasp file and then a fingernail file. It’s faster than using just a file.
