It seems like I can hit my local repeaters as is...
"Hitting" a repeater and being able to carry on a conversation with another repeater user are two different things. You may be hitting the repeater, but your signal may still have low signal strength and be noisy to other repeater users.
Here's a suggested progression of coax types for a VHF/UHF home station: RG-58, RG-8X, LMR-240, RG-8, LMR-400. Each step up the progression comes with a higher cost.
There are several coax loss calculators on the Internet. For this discussion, I'm going to use the one at:
Coax Loss Calculator | KV5R.COM
For all of these calculations, here is the power delivered to the antenna assuming 50 feet of coax, transmitting on 146 MHz at 5 watts with a 1.2:1 SWR, and ignoring the losses in connectors:
| Cable | Power (watts) |
| RG-58C (Belden 8259) | 2.3 |
| RG-8X (Belden 9258) | 3.1 |
| Times LMR-240 | 3.5 |
| RG-8 (Belden 8237) | 3.8 |
| Times LMR-400 | 4.2 |
Now, let's move to 446 MHz and use the same parameters:
| RG-58C (Belden 8259) | 1.1 |
| RG-8X (Belden 9258) | 1.9 |
| Times LMR-240 | 2.7 |
| RG-8 (Belden 8237) | 3.0 |
| Times LMR-400 | 3.7 |
Coax loss is not a trivial thing. I wouldn't dismiss it.
