magicwalnut
- Joined
- Sep 16, 2022
- Messages
- 1
So I recently got a HT1250 radio and successfully programmed channels and zones I want with CPS R06.12.5.
One problem I had was that the assigned zone button wouldn't change the zone. I found online that I needed to upgrade the firmware, so I tried that.
I was following a tutorial and installed the factory(I think??) codeplug from the samples that came with US Waris Lab tool, after that the radio shows "EEPROM HW ERR". I then tried to upgrade the firmware but it just says Radio not in bootstrap mode (I had pin 12 shorted to ground/pin 7, and the radio behaved like it was in bootstrap mode).
Radio model is H25RDH9AA6
I have the codeplug from CPS saved from after I got my channels programmed, but when I try to push that (or read from the radio) I get a region not supported type of error, even thoug I did that "mod" which would unlock all regions and it worked fine before I flashed that factory codeplug.
Thanks a lot in advance for any help!!
