I have been a reader of the forums but this is my first post.
I sent my SDS200 in for warranty repair because there was an annoying loud pop noise at the beginning and end of transmissions when receiving any AM transmissions. It didn't matter what band, CB, civil aviation, or military air. Not only could you hear it through the SDS200 speaker but you could also hear it on recordings of AM transmission downloaded and played over a computer, which to me indicates the problem is happening before the audio output stage.
The problem is easily duplicated by removing the antenna (so no transmissions interfere), turning the volume up to 8 or 9 so you can easily hear it, then turning the squelch knob to open and close the squelch. When the squelch opens there is a pop noise and when the squelch closes there is a pop noise.
I just received an email saying my repair case is closed with the following comments.
Technician Inspection Comments Customer stated, when listening to air band there is a pop at the beginning and end of transmissions.
I tested the unit and yes there is a pop, but i test several SDS200 unit and they all have the same pop.
Technician Repair Comments
Comments UNIT PERFORMS TO FACTORY SPECIFICATIONS
So after spending $30+ dollars to ship and insure the scanner and waiting over 6 weeks I am told no repair was done because other SDS200's have the same problem.
Is this true? Does anybody else have this problem with their SDS200? I don't recall having the problem when I first got my SDS200 and I don't see any complaints about it here on the forum. Could it be the only SDS200 scanners the technician tested are defective ones that came in for repair?
If other SDS200's have this problem wouldn't this be another issue that needs to be addressed by Uniden like the hum problem?
Any feedback would be appreciated as this has left a bad taste in my mouth for Uniden.
