NWI_Scanner_Guy
SCANNING THE AIRWAVES SINCE 1987
There is a learning curve, but most of it is due to the complexity of modern trunked radio systems. Investing the time to learn the unit is well worth it.
Truth!!
I toggled sites of my statewide system by hand and that alone was a Major PITA due to there being hundreds of them. Couldn't even image trying to do talkgroups by hand.That's really handy with large trunked systems with over 1000 talkgroups; manually toggling each one would be a ridiculous PITA.
That's best done with location control, all distant sites automatically get toggled off.I toggled sites of my statewide system by hand and that alone was a Major PITA due to there being hundreds of them.
I now have the entire system as a FL l will use location control with and I have a small regional chunk of the same system on another FL with most sites on avoid.That's best done with location control, all distant sites automatically get toggled off.
I set full DB to on and all others to off and location control on and didn't really care for it, so I went back to scanning my edited statewide system and nothing else.Don't scan both FL at the same time. You want to scan a system once with whatever you want to hear enabled. Scanning it multiple times is inefficient and you'll miss more traffic.
I'm sure you meant 436 & 536, not '486...'.I guess there’s something to be said for living in the sticks! Well, a smaller town anyway. Lawton. We just don’t have many systems to choose from. The OKWINP25ll is it. Set up police, fire, EMR, OHP, I’m good to go! Well, I do have other conventional systems for scanning on other FL’s. I take it the SDS’s are similar in programming to the 486/586 series?
Haha yes!! Had computers on my mind!!I'm sure you meant 436 & 536, not '486...'.
Same here. I tried the full DB when I was recently trying the GPS in the car. There are too many backup to backup frequencies in the full DB that are almost never active. With the full DB the scanner ends up spending a lot of time checking frequencies that are virtually never active and you end up missing a lot of transmissions.I set full DB to on and all others to off and location control on and didn't really care for it, so I went back to scanning my edited statewide system and nothing else.
This is what I did, and for several states. Not just for SDS, but for all of my scanners. It's definitely a hobby keeping the local data updated.I'm in the process of putting together my own edited statewide list, but it's a long process going county by county and trying to wade through the details of each.
That's what I did and the favorites list I'm monitoring is only a small chunk of the entire statewide system.I'm in the process of putting together my own edited statewide list, but it's a long process going county by county and trying to wade through the details of each.
You don't like using service types? I don't think I'd want to set all those to Avoid because I might just want to listen to them at some point. For instance, I don't normally want to listen to the highway department, but when the weather turns bad those guys are just as active as the police. It's a lot easier to enable the appropriate service type than to go through all those system and toggle the Avoid settings.This is just one city with most channels avoided.
I do use service types and I do listen to the highway department. Akron is quite a distance from me and I'm not interested in monitoring that region. I actually went back later and avoided that entire department.You don't like using service types? I don't think I'd want to set all those to Avoid because I might just want to listen to them at some point. For instance, I don't normally want to listen to the highway department, but when the weather turns bad those guys are just as active as the police. It's a lot easier to enable the appropriate service type than to go through all those system and toggle the Avoid settings.
