gr-osmosdr 0.1.4 (0.1.4) gnuradio 3.7.10
built-in source types: file osmosdr fcd rtl rtl_tcp uhd miri hackrf bladerf rfspace airspy soapy redpitaya
Using device #0 Realtek RTL2838UHIDIR SN: 00000001
Found Rafael Micro R820T tuner
[R82XX] PLL not locked!
Using two-stage decimator for speed=960000, decim=10/4 if1=96000 if2=24000
Project 25 IMBE Encoder/Decoder Fixed-Point implementation
Developed by Pavel Yazev E-mail:
pyazev@gmail.com
Version 1.0 (c) Copyright 2009
This program comes with ABSOLUTELY NO WARRANTY.
This is free software, and you are welcome to redistribute it
under certain conditions; see the file ``LICENSE'' for details.
op25_audio:
pen_socket(): enabled udp host(127.0.0.1), wireshark(23456), audio(23456)
p25_frame_assembler_impl: do_imbe[1], do_output[0], do_audio_output[1], do_phase2_tdma[1], do_nocrypt[0]
Reading blacklist file
added talkgroup 7101 from blacklist.tsv
added talkgroup 7102 from blacklist.tsv
added talkgroup 7242 from blacklist.tsv
added talkgroup 7116 from blacklist.tsv
added talkgroup 7264 from blacklist.tsv
added talkgroup 7288 from blacklist.tsv
added talkgroup 7289 from blacklist.tsv
added talkgroup 7292 from blacklist.tsv
added talkgroup 7295 from blacklist.tsv
added talkgroup 7304 from blacklist.tsv
added talkgroup 7315 from blacklist.tsv
added talkgroup 7316 from blacklist.tsv
added talkgroup 7328 from blacklist.tsv
added talkgroup 7320 from blacklist.tsv
added talkgroup 7358 from blacklist.tsv
added talkgroup 7363 from blacklist.tsv
added talkgroup 7368 from blacklist.tsv
added talkgroup 7398 from blacklist.tsv
added talkgroup 7404 from blacklist.tsv
added talkgroup 7406 from blacklist.tsv
added talkgroup 7412 from blacklist.tsv
added talkgroup 7429 from blacklist.tsv
added talkgroup 7442 from blacklist.tsv
added talkgroup 7453 from blacklist.tsv
added talkgroup 7455 from blacklist.tsv
added talkgroup 7467 from blacklist.tsv
added talkgroup 7469 from blacklist.tsv
added talkgroup 7502 from blacklist.tsv
added talkgroup 7503 from blacklist.tsv
added talkgroup 7513 from blacklist.tsv
added talkgroup 7533 from blacklist.tsv
added talkgroup 7547 from blacklist.tsv
added talkgroup 7552 from blacklist.tsv
added talkgroup 7558 from blacklist.tsv
added talkgroup 7572 from blacklist.tsv
added talkgroup 7582 from blacklist.tsv
added talkgroup 7653 from blacklist.tsv
added talkgroup 7655 from blacklist.tsv
added talkgroup 7716 from blacklist.tsv
added talkgroup 7746 from blacklist.tsv
added talkgroup 7851 from blacklist.tsv
added talkgroup 7853 from blacklist.tsv
added talkgroup 7999 from blacklist.tsv
added talkgroup 8001 from blacklist.tsv
added talkgroup 8116 from blacklist.tsv
added talkgroup 8126 from blacklist.tsv
added talkgroup 8133 from blacklist.tsv
added talkgroup 8151 from blacklist.tsv
added talkgroup 8196 from blacklist.tsv
added talkgroup 8226 from blacklist.tsv
added talkgroup 8227 from blacklist.tsv
added talkgroup 8228 from blacklist.tsv
added talkgroup 8412 from blacklist.tsv
added talkgroup 8413 from blacklist.tsv
added talkgroup 8414 from blacklist.tsv
added talkgroup 8516 from blacklist.tsv
added talkgroup 8522 from blacklist.tsv
added talkgroup 8592 from blacklist.tsv
added talkgroup 8651 from blacklist.tsv
added talkgroup 11301 from blacklist.tsv
added talkgroup 11313 from blacklist.tsv
added talkgroup 11323 from blacklist.tsv
added talkgroup 11324 from blacklist.tsv
added talkgroup 11327 from blacklist.tsv
added talkgroup 11314 from blacklist.tsv
added talkgroup 11334 from blacklist.tsv
added talkgroup 11520 from blacklist.tsv
added talkgroup 11522 from blacklist.tsv
Traceback (most recent call last):
File "./rx.py", line 924, in <module>
rx = rx_main()
File "./rx.py", line 838, in __init__
self.tb = p25_rx_block(self.options)
File "./rx.py", line 196, in __init__
self.open_usrp()
File "./rx.py", line 765, in open_usrp
self.__set_rx_from_osmosdr()
File "./rx.py", line 693, in __set_rx_from_osmosdr
self.__build_graph(self.src, capture_rate)
File "./rx.py", line 323, in __build_graph
self.trunk_rx = trunking.rx_ctl(frequency_set = self.change_freq, debug = self.options.verbosity, conf_file = self.options.trunk_conf_file, logfile_workers=logfile_workers, meta_update = self.meta_update)
File "/home/pi/op25/op25/gr-op25_repeater/apps/trunking.py", line 720, in __init__
'sysid': None})
File "/home/pi/op25/op25/gr-op25_repeater/apps/trunking.py", line 730, in set_frequency
self.frequency_set(params)
File "./rx.py", line 416, in change_freq
self.decoder.reset_timer()
File "/home/pi/op25/op25/gr-op25_repeater/apps/p25_decoder.py", line 149, in reset_timer
self.p25_decoders[index].reset_timer()
AttributeError: 'p25_frame_assembler_sptr' object has no attribute 'reset_timer'
