Did Motorola Digital Radio Equipment Lead to Cincinnati Firefighter's Death?
tmfok7
Far Eastern Washington...
Hopefully, administrators will swallow their pride and pay heed to what is going on with these systems. If they are having this much problem with just the digital, then what are they experiencing with encryption on top of that?
rdale
Lansing, MI
"The International Association of Fire Fighters is now recommending fire department not use digital systems in fires."
So the IAFF used to be onboard with digital? Ouch...
K8TEK
Banned
Ohio
According to NFPA 1221, they recommend using neither trunked or digital.
scannerman1111
Georgia
Sounds like a user/training problem to me! No radio system is 100%. What happend to good tactics? The best radio system in the world is not going to protect someone. Following good tactics and standards will reduce the risk. Lets face it, piblic safety work is very dangerous. Blaming the radio system is not the problem.
idontknow82
Wisconsin
They could have gotten hand held walkie talkies from walmart for 35 dollars instead of 35 million to talk to each other in the same building, the walmart ones would of done the job. To talk farther away yeah those cheapies aren't going to work, and apparently the 35 million dollar ones didnt either!
poppafred
North Central Texas
What is with this obsession with encrypting everything that everybody says over the radios?
Digital adds another layer of difficulty to communications, as one dropped character scrambles the entire transmission. I hear that all the time with the state police here. Adding encryption just makes it that much more complex. Is suggesting doughnuts and coffee that sensitive a subject? Heck, everyone has to eat.
Motorola makes a big deal out of the "security" side with digital and encryption, they probably never mention the complexity and missed calls that result.
Just because you CAN do something is not always an indication that you SHOULD do something.
Encrypting fire ground comms is stupid. And two good people paid for that stupidity with their lives.
N4DXX
In the pines where the sun never shines
It was inevitable,But somehow i think we all knew it was going to happen sooner or later..And it will happen again..No doubt.I agree motorola should have to pay and i am sure they will..via lawsuit.Victems family should be awarded the 35 million the system cost and motorola should declare it a failure and be forced to install a reliable analog system.Now maybe this will get some attention and motorola and others won't be pushing the digital craze so hard..
N
N_Jay
Guest
Maybe you missed the fact that the new system works better then the old system?
Oh, wait, you don't bother with facts. Never mind.;)
N
N_Jay
Guest
This has NOTHING to do with encryption.
You sure?
Where did it say anything aapount encryption?
I think that the "obsession with encryption" seem to be in this thread.;);)
N
N_Jay
Guest
And what is the findings are that there were training or procedural problems? (as there are in almost every one of these cases.)
No, it can't be that?
If the emergency call was recorded by the system, how did it get missed by the Incident command and dispatch center? (Inquiring minds want to know)
Of course some here are able to come to THEIR conclusions without being hampered by facts.
gmclam
Fair Oaks, CA
The problem is not trunked, the problem is repeated. It makes little sense to me that governments force fire fighters to use radios that transmit on a frequency that must be recieved many miles away and repeated on a different frequency back to a location only several yards away from where the fire fighter is. DIRECT communication is the key here.
Funny [sic] because Motorola makes most, if not all, of their profits from taxpayer money used to buy these systems that most of us don't want.
mdulrich
Van Wert, Ohio
One dropped character does not scramble the entire transmission. There is error correction that corrects for these sorts of things until so much is dropped that you will lose part of the conversation. It takes quite a bit to lose the entire transmission.
The fire talkgroups are not encrypted on that system so that doesn't enter into this discussion. If it was encrypted again it is the same error correction that kicks in.
And don't compare what you hear on your scanner with what the system radios are hearing.
Mike
mdulrich
Van Wert, Ohio
You obviously havn't been in a structure fire doing fire suppression. The $35 Walmart radios wouldn't make it through 1 good fire. The expensive Motorola radios sometimes don't make it.
Mike
idontknow82
Wisconsin
Speaking of not bothering with facts N_jay, THERE WERE DEATHS. Why continue to defend these hazardous digital systems you seem to be SO fond of?
N
N_Jay
Guest
Can you please tell me the technology that we should not stop using because it has never been associated, even in an indirect manner with anyone's death?
Please, name one.
Just one.
Maybe you should stop GUESSING and ASSUMING you know it all, and actually look into a few of the FACTS on both sides of this very complex issue.
Your simplistic "They are all wrong" attitude does NOTHING for any of the people working hard to help our first responders with the very best tools available.
