Did you get a Pro-96 for Xmas?
jimmnn
Colorado
Anyone who may have been lucky enough to receive a Pro-96 under the tree and now is confused about monitoring the states DTRS system.
Just fire away with any questions you might have, we are here to help.
Merry Christmas to all!
Jim< :p
scotsman
New 96 for Christmas
Yep, I got one, but Rad Shack didn't have clue what a scanner was let alone how to help program it. I have a PRO-94 which I have program to scan Denver's older trucked system, but want to listen to Jefferson County and Lakewood activity.
What is the best way to start programming this scanner? Do I need to have all the Info input to it statewide or can it work off just the control freqs?
I know I sound like a complete novice, and I am when it comes to this new scanner. I also think I've been given a whole lot of false and confused info.
Thanks for any insights you may have,
the Scotsman
jimmnn
Colorado
Re: New 96 for Christmas
the Scotsman
Control channels are just fine and you don't need the entire state, just 2 or 3 in the area your located to start with.
I would also suggest purchasing the programming cable and using win96 software that sure makes things a lot easier.
Depending on your location there are also some predefined win96 files for the front range on http://www.radiohacker.com/ and those certainly help.
Also check the RR database on this site and remember while the system id's are pretty accurate many of the system frequencies "control channels" are not.
Good luck and keep in touch! :)
Also my Pro-96 is online 24/7 if you want to compare.
http://www.live365.com/stations/jimmnn2
Jim<
