Difference Between motorola cdm1250 and cm 300 programming cable
NPeters481
Dexter, NY
Difference Between Motorola cdm1250 and cm 300 programming cable. Especially if you can show me an image or a way to make a cdm1250 cable program a cm300 radio.
NCFire11
The cable should work on either model, it just plugs into the phone jack where you plug the mic in.
mancow
N.E. Kansas
No, they are different. There is one wire that needs switched in on the CM to initiate programming mode. Cruise Batlabs and you should be able to find the difference. I would tell you but I don't have the info handy right now. I modded our factory CDM cable that has the metal box in the middle with a BNC audio test port. I added a toggle switch to switch between CDM and CM mode.
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
I made up an adapter from an RJ45 surface mount wall jack and cut an RJ45 patch cord in half. The cross-wiring necessary to convert from the CDM mic pin out to the CM mic pin out is done in the surface mount housing.
Just plug the CDM cable into the adapter and it's ready for the CM's.
I can not find my notes on the wiring changes, however. IIRC, you just have to make a couple of swaps.
SteveC0625
Found it!
Jumper mic Pin 1 to Pin 3. Pin 1 is 9.3 volts. When applied to Pin 3, Pins 2 and 7 are configured to "boot" and "sci" respectively.
The only other lines that need to go into the mic connector are pin 4 (ground) and pin 7 (sci).
batlabs has a schematic of the CDM mic connector for reference purposes if you need it.
FWIW, the answer for this was posted over on the batboard back in 2004! The search function is your friend, it's how I found the info.
The Maxtrac,GM300 and M1225 use the basic Maxtrac mike cable programming cable with no problem.. the CM200,300 and PM400 require the jumper mentioned in the post above in order for it to work. I mounted a toggle switch on my silver satin cable to switch the pins on and out with good success.... I have programmed at least 1000 PM400s and 300 CDM1550s in the past 5 years with no problems with a homemade cable and even have on 40ft long that works well also!
wildbillx
Cape May, NJ
I have a question. I have a cheap cable (usb) that I use as a backup for 1250's. I have a cat 5/6 inline coupler, a piece of cat5 line, and ends. Can I make a jumper piece that has 2 male ends one to pm400 and one to coupler. The coupler would go to the cdm1250 male end. Sorry if im confusing you. The cdm1250 male end only has 4 wires with the tab on top starting at the left 2-4-5-6 have wires. What would the pm400 look like. Would it be 1 and 3 jumpered then 2-4-5-6 straight through?
