DSDPlus Difference in distance between DSD+ and FMPA
BM82557
Berkeley Co WV
I am using FastLane 2.235, I just noticed this afternoon that there is a difference between the distance noted in the Event log and what is displayed in the FMPA window. In my case DSD+ has 49.2 M and FMPA has 30.7 M. I don't know if this started with the latest version or has been am ongoing issue from past versions. I've included a screen capture that is probably hard to read -Screenshot - 2_16_2020 , 18_18_07.png
thewraith2008
In FMPx.cfg and DSD+ Menu > Misc. Do you have the units the same.
FMPx.cfg = (search units (miles or kilometers).
DSD+ = Metric or Imperial checked.
thewraith2008
Are you able to test with FMP24 to see if you get the same result.
If it's OK using FMP24, then FMPA may have a bug which you can report to DSDPlus.
thewraith2008
I just did a test.
I changed my FMP24.cfg to miles and DSD+ to Imperial and I get same difference you see.
I normally use km and metric and it's OK using that.
I'd report that as it looks like a bug.
