n9upc
Not really. DMR (TRBO) uses a 12.5 kHz channel (2.5 kHz dev), period. Due to the time division, you get 2 channels in that 12.5 kHz step so it is equivalent in terms of occupied band width to running twin 6.25 kHz channels (at 1.25 kHz dev).
NXDN (NextEdge, iDAS) only gives a single channel. It can be either 12.5 kHz wide or 6.25 kHz wide. So to get two channels in 6.25 kHz would require two repeaters.
Thus the debate between NXDN and DMR (in the US). NXDN subscribers are cheaper (roughly 40% the cost of DMR subscribers). However, the 6.25 kHz thing means it is much more expensive to get two channels in a 12.5 kHz space requiring either 2 times the number of sites or a multicoupler (couple thousand dollars right there) at each site to get the same system capacity as DMR. NXDN favors the consumers, DMR favors the system owners due to same capacity on half the hardware (minus 1 time slot for control on a trunk system).
Yes thank you for restating what was stated there. However, C4FM is more like a format where as FDMA Is more of the roadway. You can run CQPSK on FDMA also and then do not forget vocoding.
As for C4FM with Fusion if you really look at the comparison to p 25 you will see that the frequencies used between the two technologies are different as well as some slight data framing. It is not surprising that Yaesu did that in order to not have to pay large sums of money for patents. If you search the internet you will see some experiments that have been done already with software defined radio that allow the reception of fusion and p25.
As a matter of fact a classic example of this is the new DV4mini that allows transports of data streams for fusion, DStar, and P 25.
