Different firmware cps on same pc.
oaa
Bygland Norway
Is it possible to run two different cps firmware versions on the same computer, or will it cause trouble?
gary123
If you are talking different CPS and thus codeplug versions IE R27, 30 and 36 then yes you can run them all on the one machine. The FW is in the radio not the CPS. I have seen radios with FW16 and CPS R35. The only thing to remember is once the codeplug is updated to a higher number you cannot roll it back even if you have a archived copy at the earlier version.
  • Like
Reactions: oaa
