- Joined
- Dec 19, 2017
- Messages
- 1
Hi
Building a mobile internet setup for in vehicle WIFI and has to be capable of streaming video.
I have a USB dongle that is powered on with the vehicle dual battery and relay and is connected to the Australian Telstra 4GX network.
The dongle accepts 2 external antenna to enable MIMO. I have the required pigtails for the connectors. Port one will be connected to the low profile antenna for the hilly areas where the tower drops out MIMO and goes back to SISO.
I am wanting to use 2 different gain mobile antennas. One mounted on the bullbar of the vehicle and on on the rollbar of the ute tray above the roof line.
the antenna are the following:
RFI CD7195 - 3G+4G+4GX Bullbar Mobile Antenna
RFI CSM700 Low Profile 3G+4G+4GX M2M Antenna - 700-2700MHz
Will this work having MIMO transmission of different gain antenna or do the antenna need to be matching gain, model and location on vehicle?
RFI CD7195 Bullbar Mounted 3G+4G+4GX Antenna
4.5 - 6.5dBi gain - band dependent. 700-2700MHz. Non MIMO. Ideal for commercial vehicles, 4X4 & trucks. 5m low loss coaxial cable & female FME connector incl.
www.telcoantennas.com.au
RFI CSM700 Low Profile M2M Antenna
2 – 5dBi gain. 700-2700MHz. Easy installation with stud mounts, used in a range of M2M applications. 1.25m RG58 cable and SMA male connector included.
