SDRuno Is Good
just got setup with sdr n its great.
now I'm wondering what kinds of receiving with different software can sdr be used for..
I'm interested in any suggestion please. instead of bumbling around id rather ask directly in here n learn from the start..
What do you use your SDR for with what software Please ??
Cheers Robby J
I like HDSDR mostly and use SDRuno for RTL-SDR. SDRuno gives you full FM stereo sound and does not require any dependencies to be installed by the user.It is essentially Studio1 made into freeware for SDRPlay RSP1 and RSP2.(I am not favor of SDR# because it uses closed open source code from other developers.)
For SDRuno to work with rtl-sdr download version 1.13 from
Downloads – SDRplay
Download the RTL-SDR EXTIO DLL from
http://hdsdr.de/download/ExtIO/ExtIO_RTL2832.dll
Install SDRuno 1.13
Copy or move the ExtIO_RTL2832.dll to C:\Documents and Settings\YOUR USER NAME\My Documents
Leave it there or SDRuno won't work with RTL-SDR!!!
After those steps are done we run SDRuno (EXTIO) for RTL-SDR. Do not try to run the main SDRuno because that one is for the RSP1 and RSP2!!!!
You will have to press some buttons, in SDRuno Main to bring up the radio console and the waterfall/spectrum view. Press RX and SP2.
If you want to change RF Gain, PPM, and such you have to press OPT>>Select Input to bring up the menu that has REALTEK RTL2832.
To decrease the sample rate you have to use the up or down arrow keys that say Sample Rate. Just click 2400 kbps to make blue highlight then use up or down arrow keys.After your finished making adjustments, press START button on SDRuno Main to listen to your RTL-SDR.
Here is a great tutorial video for SDRuno and RTL-SDR
https://www.youtube.com/watch?v=4CihRWoDL5A
Good Help here:
http://www.radioforeveryone.com/2016/07/rtl-sdr-with-sdruno-first-steps.html
Great FM Sound!!
