T
Tryceleon525
Guest
I don't think there has much difference between digital vs Analogue Antena.
These antennas apparently receive and not receive simultaneously whereas a digital antenna only receives ones and zeros.
I don't know a lot about this and try not to make a jerk out of me but I feel it coming. You sound like you know what your talking about. I listen to my Home Patrol and hear the digital signal from the Sheriff of Sussex County New Jersey and the New Jersey State Police Trunking that I don't know if its digital. This is being heard while using my RS Discone antenna. When I hook up my Diamond x510 2meter 440 ham antenna I don't get the State Police Trunking or the Digital Sheriff signals. This Diamond is 30 feet higher and using better LMR-400 CABLE. Is there a reason? How can I get these signal better on my discone? Thanks Ron
Ron,
Digesting down the conversation, you indicate you have a X510 antenna (8 dB gain at 144-148 MHz, and 11.7 dB gain at 440-450 MHz). You are trying to hear P25 signals on 154.845 and 155.430 MHz [Sussex Sheriff], and on the 851.0-861.0 MHz band [NJSP] using a high-gain antenna that is not designed for the frequencies you are trying to receive.
The Discone antenna is a low-gain antenna designed to cover a very broad range of frequencies. If you are hearing both systems on your Discone, then terrain isn't a big a factor as you may think. The x510's lack of resonance at the frequencies that you want to receive is the key factor.
Hope this helps.
Don
All great answers. Now I know where the frequencies are that I'm trying to hear that I didn't know I can get working on an antenna that will get the frequencies. Either boosting my discone or getting a different antenna which is better. Any suggestions of what might be better and get both frequencies. Thanks All Ron
The benefit to a discone antenna is that they have an extremely wide usable bandwidth, however they have zero gain. They are useful for a scanner listener when there is a strong signal present, and they are useful if you are going to need an antenna that will transmit on many different frequencies.
If you are trying to receive something in the 700-800MHz band, you will get much better performance from an antenna that is specifically designed to work on those frequencies and has some gain. Getting yourself a wide band 700-800MHz base antenna with a couple of dB of gain will probably help your reception quite a bit.
"These antennas apparently receive and not receive simultaneously whereas a digital antenna only receives ones and zeros."
HUH? Antennas are in affect just metal wire that is energized by the RF energy which creates currents in the wire and transmitted to the receiver.
The receiver itself determines if it analog or digital signal imposed on the incoming RF.
Zeros & Ones?? Come On now!
To Clarify:
The radio wave (frequency) is NOT digital.
What is 'digital' is the information (sound, data, etc.) that is being carried on the radio wave.
An antenna tuned for what ever frequency the system operates on.What is the best antenna for apco p25 narrow band
And, the antenna has NO way to determine if the signal is digital. Sales hype....
You may want to read all the posts in this thread before asking questions.What is the best antenna for apco p25 narrow band
800.00 to 870.00 mhz
Apco P25-2
