Blink962
Can someone answer with some certainty this question for me so I can put this subject behind me.
Are digital voice authorized on the GMRS band.
47 CFR § 95.1731 - Permissible GMRS uses.
www.law.cornell.edu
§ 95.1731 Permissible GMRS uses.
The operator of a GMRS station may use that station for two-way plain language voice communications with other GMRS stations and with FRS units concerning personal or business activities.
(a)Emergency communications. Any GMRS channel may be used for emergency communications or for traveler assistance. Operators of GMRS stations must, at all times and on all channels, give priority to emergency communications.
(b)One-way communications. The operator of a GMRS station may use that station to transmit one-way communications:
(1) To call for help or transmit other emergency communications;
(2) To provide warnings of hazardous road conditions to travelers; or,
(3) To make brief test transmissions.
(c)Travelers assistance. The operator of a GMRS station may transmit communications necessary to assist a traveler to reach a destination or to receive necessary services.
(d)Digital data.GMRS hand-held portable units may transmit digital data containing location information, or requesting location information from one or more other GMRS or FRS units, or containing a brief text message to another specific GMRS or FRS unit.
47 CFR § 95.1771 - GMRS emission types.
www.law.cornell.edu
§ 95.1771 GMRS emission types.
Each GMRS transmitter type must be designed to satisfy the emission capability rules in this section. Operation of GMRS stations must also be in compliance with these rules.
(a) Each GMRS transmitter type must have the capability to transmit F3E or G3E emissions.
(b) Only emission types A1D, F1D, G1D, H1D, J1D, R1D, A3E, F3E, G3E, H3E, J3E, R3E, F2D, and G2D are authorized for use in the GMRS. Equipment for which certification is sought under this subpart may have capabilities to transmit other emission types intended for use in other services, provided that these emission types can be deactivated when the equipment is used in the GMRS.
47 CFR § 95.1787 - GMRS additional requirements.
www.law.cornell.edu
§ 95.1787 GMRS additional requirements.
Each hand-held portable unit transmitter type submitted for certification under this subpart is subject to the rules in this section.
(a)Digital data transmissions.GMRS hand-held portable units that have the capability to transmit digital data must be designed to meet the following requirements.
(1) Digital data transmissions must only be initiated by a manual action by the operator, except that GMRS units may automatically respond with location data upon receiving an interrogation request from another GMRS or FRS unit.
(2) Digital data transmissions must not exceed one second in duration.
(3) Digital data transmissions must not be sent more frequently than one digital data transmission within a thirty-second period, except that a GMRS unit may automatically respond to more than one interrogation request received within a thirty-second period.
(4) The antenna must be a non-removable integral part of the GMRS unit.
(5)GMRS units must not be capable of transmitting digital data on the 467 MHz main channels.
(b) [Reserved]
I moved to 900MHz Motorola DTR and DLR digital radios
What's your favorite models?
There is still analog on the ham bands??
Allowing digital and analog modes on the same uncoordinated channels is an absolute disaster. Let's hope FCC doesn't allow it.
Truthfully, it makes no difference. While not super regular, you hear it pretty often out here in SoCal, along with FM on CB, etc. The FCC doesn't care and doesn't have the money to enforce the regulations. So whether they allow it or not, that disaster is going to happen, especially with the prevalence of CCRs.
Doesn't seem like it.There is still analog on the ham bands??
I'm curious as to what you are hearing. Is it simplex traffic or are you hearing it on repeaters. As far as I know there are no manufacturers of "Cheap Chinese Repeaters"
It's simplex, not over repeaters. It's DMR on the FRS/GMRS channels.
Were you able to listen to the traffic?
There was a -large- nationwide radio shop that got busted for putting commercial users on GMRS frequencies many years ago. They were not the first, and I'm sure they won't be the last. Lots of schools being dumped on GMRS either by radio shops or IT guys that don't understand radio.
I kinda remember that happening. Very well could be left over from that. Unfortunately, it just hasn't been regular enough to catch.
