Hi, this is my first post, and i hope it´s in the right place. Tried search but din´t find anything similar to what i need.
My objective is to transmit a voice signal at least a few hundred feet. It can be mono, and of reasonable quality. I also want to transmit digital data, in this case, to control a few servos, without the digital data being heard on the voice signal.
I has hoping to transmit at least 16bytes per second. (the higher the better, but reliability is more important). I can include check sum´s in the sent data to avoid errors.
One idea i have to do this is to use a standard FM or AM transmitter (like the ones found in ebay), and use a micro-controller to add a high frequency component to the transmitted signal (Frequency-shift keying). The receiver would then have a filter to separate the high frequency from the voice signal, and feed it to another micro-controler, that would decode the signal.
Also i would like the signal to be able to penetrate walls and buildings (the lower the frequency the better right? AM?).
Don´t want to burden anyone, but would appreciate suggestions/critics, and to be pointed in the right direction. The details i think i can workout on my own.
Thank You
Thank You
