digital scanners and non digital scanners
N
nec208
Guest
Okay is it true that the best digital scanner is the BCD396T?I think the best none digital scanner is the PRO-97 do to good reception ,clear signal and good manual.
But I will see what other members comment on what they say about this, that knows lots more than me about scanners.
I just would like digital scanners to cost $200 to $300!! But it does not look like that will ever happen:(
mciupa
Canadian DB Admin
Moderator
I'm here a lot
Why only Uniden and RadioShack ?
How about the new GRE products ? PSR 500 etc...
A new $200 to $300 digital ... No .
There are good used deals (slightly more than your purchase window) for digital out there if you are motivated .
Stick0413
Hopewell, VA
Yeah I must agree the GRE PSR-500 and its brother the PSR-600 are the best on the digital side right now. As far as the non digital the GRE PSR-300 and PSR-400 are basically the same as the 97 but updated.
N
nec208
Guest
I don't have money to pay more than $200 to $300 even a digital scanner 2 or 3 years old.
Ch1ronTL34
well that stinks...I guess you're out of luck...pointless thread
N
nec208
Guest
What about the old BC250D? May be I just got bad BC250D?
And should just get other BC250D?
There should be dam laws to stop the rich companies from robbing us.
RMH77
Holiday FL
Save your pennies for the digital! When i got back into scanning i just bit the bullet and bought the 996T. No regrets
Raven95150
Nowthen, MN
You just have to look in the right places. Ebay, pawn shops, craigslist are a few things you could try. I got a PRO-96 at my local Pawn America for $199 and they currently have a 2096 for $279.
The 250 is not rebanding-friendly. Since rebanding has started in some areas, it will be a paperweight soon.
N
nec208
Guest
I guess thats the only option or hope there is new generation scanner.There is not much to talk about now in this thread .
I guess problem scanners is dying out and not profitable for makers to have it at $300..
n2mdk
Ames, IA
No the problem is the licensing fee the companies have to pay for the use of the digital decoding. For all we know they have to pay a pretty large fee for every scanner they produce that has it.
loumaag
Silent Key - Aug 2014
Katy, TX
Whereas this is true, the biggest problem with the 250 is that it will not work on Project 25 systems.
loumaag
Katy, TX
Airdorn said:
Gentlemen, you've been trolled.
And your reason for making this Off Topic comment and not reporting the post is...? Don't bother to answer, just reminding you that you are in the wrong with that comment.
