Digital threshold level
joey123
nj
Any idea what the digital threshold level should be for Camden County and Burlington County New Jersey for EMS and Fire
w2xq
Mentor
Burlington County, NJ
I don't know what radio you are referring to, but on my DMR handheld I set it to 1. That's one step above the minimum squelch setting.
joey123
nj
It’s horribal audio on my scanner I have a bcd436hp just wondering if what threshold I could use from 1to 9
w2xq
Mentor
I wouldn't expect a squelch setting to affect the quality of the audio one way or the other. I assume you have tried headphones or an external speaker to eliminate a defective internal speaker?
Skypilot007
Medford, NJ
Camden county is rough with the linear simulcast distortion. Even if you are within the coverage area the audio coming out of a scanner is usually crap. You may need to upgrade to the SDS100 or SDS200. Supposedly these new scanners can handle the linear simulcasting. You shouldn't have any problems hearing Burlington County with the 436 with default settings so long as you are within range of a local site.
I have noticed with the scanners, if you have all sites on the system enabled, that they will lock onto the first site it can decode even if it is on the fringe of coverage and pass traffic from that site. The signal strength from the voice channels will be poor resulting in choppy distorted audio. This requires you to force your scanner to another site with a better signal. I believe on the 436/536 scanners you can setup RSSI thresholds for site switching. If so this requires some experimentation and tweaking to get it right.
Ubbe
Stockholm, Sweden
You're probably thinking of old GRE scanners. Uniden doesn't have any RSSI switching. It's using a site as soon as it manage to open the squelch. If the system use different frequencies for different sites, and are not a simulcast system, you probably would like to lock out all sites except the strongest one.
/Ubbe
Skypilot007
Medford, NJ
You're right Ubbe, I had my brands mixed up. With the Unidens I usually just keep the distant sites I don't need to hear locked out so the scanner doesn't lock onto them.
