There are five principles defined by the FCC in the amateur radio rules. "Advancement of the radio art" is just one of those five principles.Plus, it's amateur radio. Isn't the entire point to experiment?
That's ok. Many of our users have Motorola radios, or would be willing to buy commercial if we make the move.
Yep. Our current system is UHF. We have experimented with 900mhz but the availability of hardware is very limiting.
Our current repeaters are Motorola, and I had assumed we would stick with it. Having said that, having done just a little research so far, Tait and Kenwood have some impressive products. For example, simulcast with sync over IP looks easy to implement.
We currently have 3 UHF pairs coordinated, with a request in for a 4th. The major benefit is getting out of traffic management. Right now we have contention between TGs that are currently on the same channel and time slot, while a time slot on a different channel sits idle. As the system owner we could move the TG to a different channel/slot, but it requires a massive undertaking to get every ham out there to update their codeplugs/radios. Trunking allows users to use all the TGs that are available with no contention (unless of course we get to a point where we're using all channels all the time, which is highly unlikely.) With some trunking technologies we can even add additional sites/channels without any codeplug changes. It's all exchanged on the control channel over the air.
Exactly. Plus, it's amateur radio. Isn't the entire point to experiment?
AES is irrelevant with respect to Amateur Radio given that encryption is illegal on Amateur Radio.
it’s not illegal to use encryption on amateur spectrum where I live.
At one time amateur radio lead the curve in inventing and adopting new communications technology. That ended in the 80’s.
That was just after the time when the give away amateur licenses started. You no longer had to know the material or radio electronics theory to pass the amateur radio exams. You just had to memorize the questions and the answer. Hell, you just had to memorize the question and the letter number of the answer.
Lmao brings back memoriesAgreed. However it requires ‘skills’ not discussed in public. The average user is not going to be using AES with Motorola DMR gear.
Discussing how to activate AES in gen 2 NA Motorola subs will get scum bags like Peter Wilt with HSI coming to your door, or detaining you in an airport, accusing you of supplying AES to drug cartels and terrorists.
Illegal or notAES is irrelevant with respect to Amateur Radio given that encryption is illegal on Amateur Radio.
But if they are using simplex you can’t do anything.
Illegal or not how would you stop someone from doing it?
My point exactlyYou can't
