Digital trunking scanner
Scrapmanken1
hatfield, Pa
Hi i was wondering if anyone knew of a cheap digital scanner. I want something that is around $50 if tgere is something out there for that. I bought a pro 91 analog for around that so tjought i might get a digital. Just looking for ideas.
Sent from my 2PS64 using Tapatalk
eaf1956
Evansville, IN
Good Luck with that!
Blackswan73
Central Indiana
If you want a working digital scanner, you won't find it for $50. Used, between $175-300, depending on model. New, be prepared to spend between $350-$550. You could get a SDR in your price range, but even that would require at least an analog scanner with an IF tap, and a dedicated computer. For $50 bucks you might find a android tablet like an RCA, or other low end tablet, and with a high speed internet, use a scanner app from the Play store.
NobodyS
The Skook
There are many Uniden BCD396T P25 capable scanners on ebay for around 175 dollars. I am looking at one myself
Scrapmanken1
hatfield, Pa
Would getting a motorola 800 mhz truncked radio work the same as a digital scanner. I have all of the frequencies i just cant listen to them.
