Digital TV in the USA
First off will NBC channel 10 be going digital sooner than other stations? Also, what range will the new digital audio frequencies be?
There have been several threads here on RR regarding the switch from analog to digital TV in the USA. Analog TV currently uses channels 2-69, each 6 MHz in width. ATSC (over-the-air digital) uses the SAME channels, except that after 2/17/2009 channels 52-69 will be "given back" to the government. Those channels will become the new 700 MHz band. Therefore, in addition to the requirement that all full power NTSC stations must cease broadcasting after 2/17/2009, all OTA TV broadcasting will be limited to channels 2-51.
Unlike analog where there are separate video and audio carriers, ATSC is entirely "digital data" modulated 8VSB. In order for a receiver to only decode the audio, it must first receive the entire stream and parse out the audio data. No current analog or digital scanners can do this. Who knows if there will be a market for such a receiver, and if so, how much people will pay for it. To make it happen, I think someone would have to come up with a chip or chipset that performs this specific function. Then scanner manufacturers would have to add it, and pass the cost along (with a profit of course).
Can the audio frequencies be picked up with a scanner like the Uniden BCD396T?
If your scanner can pick up the US TV frequencies, then yes. But ATSC is actually a "noise-like" transmission. So the end result is fruitless.
Also and most importantly, do you need a special antenna to receive the digital channels at full capacity?
LOL. Special? No!!! It surprises me that there are companies out there selling people "analog antennas" or "digital antennas". The antenna does not know if a signal is analog or digital, nor does it care. What is import with regard to an antenna is the FREQUENCY (or frequencies) you want to receive. One issue for many people is that their local TV has been on VHF (channels 2-13) ever since it went on the air. Although a station may be numbered 7.1 or 10.1 in digital, it is most likely NOT currently on VHF channel 7 or 10 (in my example) - you KNOW this is true if analog channel 7 or 10 is still on the air!
So you go out and pick up a new ATSC TV or converter box. You bring it home and connect it to the outside antenna you've used for years. The digital signal is not detected or "doesn't work". What you don't realize is that the digital channels are (currently) broadcasting on UHF! Is your antenna able to pick up UHF signals? Go to antennaweb.org or tvfool.com and find out where your local channels really are. Also pay attention to their "final channel" as well, because many stations will change their physical digital signal back to where their analog signal is now once the analog signal is turned off.
Bottom line; if you want to pick up both UHF and VHF (TV) signals, you need a UHF and VHF antenna!
