Digital Upgrade
amarr88
Holyoke,MA.
Not new to scanning but now have to go digital...being on a budget was hoping to get input on which model would be best for my needs...I know trx is the way to go but have a ws1040 budget or should i save up and wait...thanks
N8IAA
Fortunately, GA
Since your county now uses conventional P-25, I suggest the WS-1040 or the WS-1065. They will do the conventional P-25 at a much lower cost than the overpriced SD card scanners. I use the older cousins from RS that were made by GRE,
the Pro-106 and Pro-197. Both do an outstanding job on conventional P-25.
You should also ask in the MA state forum by clicking on the red outlined white triangle to ask a moderator to move this thread.
Then you can deal with folks that know the region:)
HTH,
Larry
amarr88
Holyoke,MA.
thank you for the responses..i purchased a used psr 800....but having a sd int issue...will have to get the whistler upgrade
