Digital voice on GMRS
alcahuete
Antelope Acres, California
Yes, he'll only need 5 different radios. What about Fusion and Dstar... I wanna play with those on GMRS too!
You can be sure /\/\ will come up with Mo-Star and Midland will have My-Star . Uniden will have You-Star. BaoFeng will have Be A Star. None of it will talk together .
Well that's why you have a standard, set by the FCC, just like you have standard emission types for CB, MURS, and almost every other service in existence. No different than dPMR, across the pond. The FCC absolutely would not make GMRS a playground for any type of digital mode you want. I can almost guarantee that, even with the FCC's stupidity.
Everyone has been caught up on this interoperability nonsense for 13 pages. There is a set standard. All radio manufacturers abide by that set standard. End of story. Now you have your interoperability. Those who want to use digital can. Those who want to use analog can. Everybody is happy.
There are a lot of "ex" GMRS proponents who swear by the DTR radios and the range they provide. What is missing are repeaters and linking. /\/\otorola has a stranglehold on two way product, however Retevis, enGenius have 900 MHz ISM products and perhaps Maxon or Hytera could develop something .
Repeaters already exist, to an extent. Linking? Not so much. I have seen a couple repeaters out there, but not many. I could absolutely see ISM replacing the current handheld bubble pack FRS/GMRS, if they were priced reasonably. The old Tri-Square radios, or whatever the hell they were called, used to be the closest thing. I think they were about $25 a piece at one point. But people are stupid. You buy one of those expecting to talk to the bubble pack radios your friends bought (FRS), find out you can't, and back to the store the radio goes. It is unfortunate.
Personally, if I'm out with a group of random folks (off roading, or boating, or such like the trip I mentioned previously), I pretty much have to use GMRS, because that's what everybody owns. I would use my DTR all day long if other people actually had them. They are fantastic radios.
NC1
Surry County, North Carolina
Maybe digital should be implemented on MURS, but no repeaters, and a 35W limit. 5 channels should be plenty of room.
How about only the 3 lower channels that are already narrow band?
tweiss3
Is it time for Coffee?
Ohio
This thread is a pretty entertaining read.
That being said, GMRS certainly appears to be written in an attempt to stupid proof the service, including power levels below those requiring an RF exposure evaluation.
That being said, I would think the biggest issue allowing digital would be to open equipment to all Part 90 equipment, which would put more trust in the users by the federal coin collectors. As it is now, the list isn't nearly big enough for GMRS equipment, imo.
The other problem I would see is putting a "preference" on which data modes are allowed. I would think it would have to be an all or none situation. It's not like a telecom bidding on the spectrum that can put whatever proprietary emission mode in that they choose, because they bought it from the FCC.
BTW, I can really get behind @mmckenna and his sense of humor.
CaptDan
Ocala, Florida
Radioddity makes a hand held radio, GD-77 that they advertise as
"...GD-77 DMR two way radio has both Tier I & II and is compatible with Motorola and other DMR radios. Official Certification: FCC ID: 2AN62-GD77; CE ID: AGC10624170902ES01..."
This a dual band radio and is capable, not necessarily legally, operating in FRS/GMRS and MURS in a digital mode, along with - if I am even allowed to say that "E" word in here.
So the equipment is out there, just a matter of time before it's being used - most likely illegally - on FRS/GMRS and MURS.
tweiss3
Ohio
There is an abundance of DMR Part 90 equipment available the could work in wither GMRS or MURS.
NC1
With FRS, you would probably not be noticed, using MURS there could be a slight possibility of being caught (maybe). On GMRS there's enough people out there to piss off who can and will find you which could result in being given a blanket party (with more if you didn't learn the first time). And then there is the possibility of the FCC taking everything electronic out of your house all the way down to your clock radio, with massive fines to follow.
On the other hand, if you follow the rules you can have what you want by using the correct service without worry.
amphibian
Canton, Texas 75103
If this endeavor succeeds, I will start a thread and note the steps for the application. From what I have read on the FCC website, it looks pretty straight forward. Still, I have reached out to intermod and will keep reading as there are some things such as experiment duration I am unsure of how long would be accepted. I observed the 24 months on that license and renewal would be routine using the web based forms, unless denied for some reason. Still, if I can get 36 or 60 months each go...why not.
@prcguy That is encouraging to know. We have plenty of sites here that cover a good chunk of central California in order to increase potential users for the "experiment".
Did you start a thread? If so, where located?
Thank you
GlobalNorth
Fort Misery
WalMart would lobby the FCC endlessly. They love MURS just the way it is.
  • Haha
Reactions: NC1
