I am a GMRS license holder and a ham. I own 10 repeaters, two of which are GMRS and do all of the maintenance on these repeaters myself. I also am a system admin for a very large trunking system. Before moving to my current position, I worked on the maintenance side (aligning combiners, repeaters, wireline cards, climbing towers, installing/removing antennas, etc.), so I know what I'm doing and am not just a "programmer."
It's analog, get used to it - or get a private business frequency pair. Those are the options for a long time to come as far as I see.
I have actually thought of doing this very thing, but since the combiners I have right now are full, that leaves me no option but to remove the GMRS repeaters at each site. So would you rather get a DMR radio and enjoy the benefits of TDMA or talk simplex in analog mode? Your attitude is pushing repeater owners away.
1) Per the GMRS rules, all legal radio's must be interoperable. That means throwing digital into the mix will go against this very rule.
And if the rules are changed, this will no longer be an issue.
2) Analog users would no longer be able to "monitor" a frequency for traffic, as digital noise would be considered interference to the user.
Very few folks on GMRS ever press the monitor button before they press the PTT and start talking. Most are using their own PL/DPL and just talk over whoever may be using the frequency. Road crews around here love to use the output of my repeaters. They apparently don't mind. Digital or analog is not going to change anyone's behavior.
3) Co-mixing digital and analog repeaters in a very close proximity can create interference. Analog repeaters hearing digital traffic on it's input can "false" with analog PL tones, keying and passing digital hash. This happens extensively in the part 90 world.
This is simply not true. I have a UHF P25 repeater and a UHF analog repeater on a single antenna (DB420) and this never happens. And this is on a site with 7 other digital repeaters (on different antennas). Digital hash does not affect the analog Quantar, ever.
At another site, I have a UHF DMR and two analog repeaters. I also had two P25 repeaters, but I moved them to a new site. None of the analog repeaters at this site have ever repeated any digital hash, even when there were three digital repeaters transmitting into the same antennas at the same time.
At another site, I have two more P25 repeaters and an analog one. This site also has four Part 90 analog repeaters for a total of seven repeaters on one antenna system. None of the analog machines have ever repeated any digital hash. If this is happening on Part 90 frequencies, then I'd argue that the repeater that is affected by digital hash is not properly setup, i.e., poor filtering, not aligned, etc.
4) Repeaters are not coordinated, so above problems would be impossible to enforce, or cure.
They aren't coordinated now, so I don't see how going digital is going to make people behave worse than they already do. It is a behavioral problem, not a spectrum problem.
5) Digital repeaters transmit more than analog systems do, because of added features like test messaging, GPS, etc. compounding above issues.
What is there to compound? You get a lot more features and two talk paths if the repeater is TDMA. Plus the individual users can use their analog radios in simplex mode and not be affected. Or they can buy a CCR DMR radio and join in on the fun.
6) Analog would no longer benefit from "capture affect" that happens with analog due to the full bandwidth transmission of digital on Co-mixed systems in a close area. It would make analog traffic unintelligible in many cases.
Have you ever tried to use an analog repeater that has another analog repeater on the same pair? It doesn't work, because they will heterodyne and sound horrible.
I don't care either way, but if the FCC ever allows digital repeaters on GMRS, I will convert both of mine. If they don't, I'll leave them in place, unless I decide to license two pairs on Part 90. There are very few people who are willing to spend tens of thousands of dollars for repeater systems and I speak from experience when I say that I do not enjoy being told that I can't change or remove a repeater from service by someone that hasn't given me a dime.
