kayn1n32008
ØÆSØ
Its Motorola in Taipei saying it is public safety grade. If it is good enough for the rest of the planet why not here?
Because tax dollars are buying it.
"Fire ground radio should go digital when the hydrants go digital!"
Digital versus Analog...aaahhh!
For what it's worth, the digital mode on shortwave (DRM) gives great fidelity but requires far higher signal strengths to be reliably decoded. You'll find that an S2 signal on shortwave analog can still be picked out of the noise. On the other hand, you need about a S9+14 signal for reliable continuous decoding with DRM.
So, horses for courses - if the public coffer is full and you can put a LOT of repeater sites up, digital will work. If you're poor, analog is the way to go.
(Myself, cynic that I am, I think that digital systems are more about the equipment vendor profit than giving the customer the best bang for the buck.)
...much deleted...
Simply put, digital offers comparable, or much better in many/most cases, performance as compared to analog FM systems.
John Rayfield, Jr.
Additionally, managing to barely key a distant repeater is meaningless if there's not enough signal to effectively get audio out.How many people compare Digital to Analog by driving away from the transmitting station until Digital drops, and then breaking squelch on an Analog channel to "see if they can make it out"? From this exercise, the anecdotes are born and forever more the belief is held that Analog gets better range. The problem is, no one drives around with their squelch broken (no one that is still sane, anyway...). In most cases, digital will still get through after the analog system will no longer break squelch, but few of these ad-hoc experiments are conducted in such a manner as to show this.
