Hi again,
It seems that some of you are confused even though I tried to keep it as simple as possible. OK, check out some of the posts further explaining band separation, no need to reiterate. Edit; Well, a bit downstream I changed my mind, read on. To answer a few questions I deliberately left hanging (I thought you understood I'm having a diplexer custom made), here we go.
Price varies with what you're having made as with anything just like a custom bike or rod. Nobody mentions how much they paid to have the Teutels build thier custom chopper, they're all different so they cost different, that's what makes them custom. I'll give you a clue, mine will set me back $100 including shipping. No, not the chopper, the diplexer. MIKEY RULES! (;->)
As for the connector question, same as above, it's a custom job. You can have the connectors of your choice. Just submit the electrical and mechanical design specifications and they'll build it.
Now to tidy up a few loose ends.
"However if you take two different single band antennas, and combine them, I think even the loss involved with the numerous coax connectors required to accomplish the hook-up, would almost defeat what was gained to begin with."
No Macomb, the idea is to keep the loss as low as possible and that's exactly what I'm doing. Please can that notion that connectors introduce loss, they don't. If that were the case radiocommunications systems couldn't operate with scores of connectors holding it all together.
"Bottom line, it probably isn't even necessary."
Oh but it IS and that's exactly why I'm doing it that way.
"A good multi-band antenna should do the job nicely."
There's no such animal, that's what makes it necessary. ALL multi-band antennas are a compromise and I refuse to compromise on quality.
You've got it right Mafia Son, while all signals are combined the STRAY signals arriving from the "wrong" antenna aren't.
To clarify Al's point on insertion loss it's 0.75dB for the diplexer vs. 3dB for the combiner. I don't know where he came up with 2.25dB but I'm not splitting hairs.
"And the cost of a decent diplexer is a lot less than the cost of an amplified multicoupler..."
Al, that depends a LOT on the diplexer and the combiner, prices vary WIDELY. More to the point, an amplified "multicoupler" is unidirectional so is totally useless for this application. Somewhere in this forum I came across "unity gain" CATV multicouplers not designed to amplify but just enough to overcome insertion loss. On the other hand CATV diplexers are made specifically with return path in mind, one port provides the return on the 5-40MHz sub band.
OK, I think that about covers all the bases. Macomb, Al pretty much covered it so go back and read it again. (pause) OK, now you're back so think filters. The low port passes signals below 600MHz only and the high port passes signals above 800MHz only. The problem with the combiner (no filtering) is that stray signals below 600MHz coming from the 800MHz antenna are interfering with those coming from the VHF/UHF antenna. By filtering them out and allowing signals from only one antenna to pass there are no strays to interfere. My VHF/UHF antenna is stone deaf at 800MHz so the reverse is not a problem. In other cases stray 800MHz signals may also interfere on that band but in any case a diplexer keeps the antennas separate. Think in the abstract and you'll get it.
Now notice I said my main antenna is deaf on 800MHz. That's an extreme case (ham antennas are rather like that) but 800 is always a problem of one sort or another no matter what antenna you use unless it's specifically for 800MHz. That's the whole idea behind using two antennas and a diplexer. No comments from the strong signal peanut gallery please, you never notice problems when you live under the tower. (;->)
Since a picture is worth a thousand words this little graphic should help you visualize how a diplexer works.
