Dipole feed line length question
brizzotheizzo
Ok, so you have an S4-S5 noise level.........what band? day or night? QRM or QRN?
Bob
Radio Oasis
All of 27mhz. All the time. I’m guessing QRN. just sounds solid and steady. Just enhanced “static”. No pulses, or patterns, just steady White Noise.
brizzotheizzo
Nothing wrong with a Y shape and for some it can get the antenna up higher. Does changing shape get part of the antenna away from things that might have noise riding on it like nearby power lines, etc? You had mentioned the antenna is used indoors and you are getting what I would expect indoors, lots of noise pickup from everything in the house.
I thought about that. But I tested the antenna outside in the tree, and in the attic. Result was the same
brizzotheizzo
So outdoors the V shape is noisier than the Y shape? Can you fit the Y shape in the attic?
The V-shaped was noisier inside and outside. And yes, I just got done installing the Y shaped in the attic. All is good with the antenna now, I just can’t explain it. How in the world does a Y dipole work better than the infamous inverted V?
prcguy
The Y would be preferred but for most people using a mast or tower, there is nothing higher to hang the wires on. There are a number of rigid aluminum Y type rotatable dipoles around. I suspect you have some noise on the feedline and a Y gets the elements a little further away from the feedline. Maybe. I dunno.
