I just made a virticle dipole antenna using #14 copper wire and pvc for aircraft monitoring and it seemed to work well on the ground when I held it up by hand. The length is three half waves so the antenna is 11.5 feet. I mounted it on the side of a metal building with the bottom of the dipole 8 feet above the roof and 16 feet above the ground. Also I used rg8-U coax. This is strictly for listening so I wanted to get best reception I possibly could.
I am a little puzzled as to why the antenna is not working any better way up in the air as it worked when I held it up by hand.
A couple questions come to mind;
Is a three half wave dipole better at recieving than a single half wave?
Is there a problem with the relation to the metal building?
I can recieve the airport sometimes on 119 mhz but the auto broadcast on 128 mhz is always better.
I might cut it to a half wave size using the formula for 123 mhz or should I just get a discone and forget it?
Oh, one other concern, when I use my Radioshack handheld scanner, the reception is worse than it was on the ground but when I use an aircraft handheld transciever, its much better than the scanner but not what I had hoped... I guess..
Any suggestions from someone in the know would be appreciated!
Thanks!
Thanks!
