"Direct" frequency for Richland co Sheriff's Dept
Lew
Lexington, SC
I Know RCSD is on the PAl 800 system and I have all the RCSD Id's.( Pro-96) My son who is a RCSD Deputy says they have a direct c/c freq. Obviously its not runked. Does any one know what this freq is?
I'm going to try to use my freq. counter the next time I see him & have him key up direct.
Lew Jernigan (USSS retired)
evan
South Carolina
My first thought would be the SCTAC/ITAC frequencies. Let us know what you find out!
jeffmulter
Fort Mill, S.C. (just south of Charlotte, N.C.)
>> You might also try 853.4875.
Lew - At one time, I believe this frequency was once classified as an itinerent channel, available to alot of licensees in and outside of public safety for simplex use. Some licensees licensed the frequency, and some did not.
Nextel acquired the rights to the frequency in a frequency auction ( 5 - 7 years ago ? ), but some 800 MHz radio users continue to operate on the frequency.
Nextel has 40 ( yes - 40 ! ) licenses covering 853.4875 for use in Richland County, and that doesn't include all the licenses covering Lexington and every county adjacent to Richland. That doesn't mean each of the sites covered in the licenses is definitely using the frequency ... it just simply means they could be.
For the scanner listener, it may mean that you are as likely to hear iDEN "noise" as you would Richland Co S-O tac communications on the channel. If an agency was using the channel in analog mode with a PL / DPL tone, setting that tone in your scanner would help.
For the public safety agency, having a working high-power iDEN signal on your tac channel can also be a "negative," due to the potential interference issues. Pinellas County, Fla. ( St. Petersburg ) was having that problem last fall, and couldn't figure out the cause of the interference until it was mentioned to them that Nextel was also licensed for the channel.
Jeff Multer
Fort Mill, S.C.
Lew
Lexington, SC
"Direct" freq for RCSD confirmed
I had a contact key up his "direct" freq and confirmed ( with my freq counter ) the RCSD "direct" freq is 853.4875 MHz. Didn't get the PL tone. Any suggestions?
Lew in Lexington
