I live on the flat DelMarVa Penninsula in Maryland.I'm dusting off my old RS 2005/6 and later family of scanners to explore getting back to railroad (and possibly marine) monitoring. Other analog scanners may be tried at a later date.
Special interest centers on the Wilmington, DE area for Norfolk Southern, CSX, Amtrak via home radio base and ops for the shortlines Delmarva Central and Maryland and Delaware RR mobile in the car.
I have the busy Baltimore CSX/NS/Amtrak main/terminals west of me at 32 miles across the Bay.
I have Wilmington area CSX/NS/Amtrak mains/yards and Delmarva rail feeds to the north at 45 miles. I WANT to try receiving Wilmington area only.
Am I correct to ascertain a gain directonal 158/162 or 161/162Mhz antenna, on a chimney, roof or tall mast (code limits to 55 feet in residential), aimed or rotated northerly (depending on terrain etc) would be a better option vs an omni directional gain antenna that will become overloaded with the closer Baltimore terminal radio operations? Some of the Baltimore signals are the same dispatchers/through rail line operations as in Wilmington (NS has different Wilmington area dispatchers), just different locations along the same rail lines and base stations running northeast/southwest through the area.
Marine band monitoring (cozy freqs with the rr band) is a side project interest where I'm assuming the marine omnidirectional antenna would be beneficial hooked to a dedicated scanner. I'd thought marine antennas, of different design, might wind up working w/2 dedicated scanners but different directional signal targets.
Thoughts?
Thoughts?
